Old 07-11-2006, 07:22 AM   #1
KronixSpeed
Guest
Posts: n/a
no, i don't think that you will need the car aligned, because of spacers. but when i put 19s on the car with my size of rubber, apparently my camber and toe were completly whack. i took the car to a porsche race team and the guy said that i need to do an alignment and toe and camber adjustments.
soo i think that you should do an alignment for sure, after you put the 19s. put the spacers on the back 7mm is all you need, any more and it will look really bad. my 7mm bring the rims out alittle any more and it wouldnt of looked good. the front i actually still have the spacers in the box, didnt use them because it looks really good with the front flushed with the rim not coming out of the wheel well.
