Old 10-26-2016, 07:26 PM   #5
Tweetdriver63
Switch
I discovered this thread, and this forum, because my 2001 Boxster suddenly wouldn't let me put the top up. Just as others described--no noise, and no movement. I went through checking the fuses and the relay, and everything else I saw here and nothing worked.
Finally, I pulled the right switch panel off and disconnects and reconnected the switch, then gave each wire connector on the back a little wiggle and a little push. Voila! The thing worked again. I didn't see anybody say anything about just checking the connection to the switch itself, so I joined to share in hopes it helps somebody.
Tweetdriver63 is offline   Reply With Quote
