Old 10-26-2016, 09:26 AM   #252
particlewave
The "cheap" projectors are just fine. I have about a dozen sets out there with the oldest being 3.5 years. No complaints.
In addition to widening the bulb socket slightly to accommodate the projectors mount post, you will need to remove some material on the shelf between the high/low sections of the OEM reflector.
Ger: test them before install to ensure the cutoff is nice and straight. If it is arced or curved, this is easy to fix before installing them. The cutoff shield is curved to follow the curve of the light and if it's curved too much or too little, the cutoff will appear arced upward or downward.
