Thread: Coolant leak
Old 10-25-2016, 07:33 AM   #15
I_like_tacos
Originally Posted by texomawaves View Post
start simple.. Did you recently loosen the reservoir cap to top it off? You can cross thread the cap and it "seems" to be screwed on right, but it isnt and your water will spew from under the cap making it look like a water pump issue. Don't ask me how I know that
No, I hadn't removed the reservoir cap prior to the leak starting. It started leaking just after shutting off the engine after a 10-15 minute casual (non-spirited) drive.
I_like_tacos is offline   Reply With Quote
