Originally Posted by particlewave
Cranks good when start lock is bypassed, but no start?
Check for voltage at fuse D5. If no voltage, then check at current distributor fusible link F2.
I think you may have a bad connection at the current distributor firewall connection (probably on the outside, not in the cabin).
You can have good voltage at the distributor, but still have a bad connection not letting enough current through. Always clean connections.
cranks good and starts and runs good. will check the plug on the firewall
