Hi,
if you turn ignition on, do you hear the fuel pump?
Did the car run fine after you started it with the battery power from another car or was that the time when the problem starts?
Did you check all fuses?
Did you put the car on a diagnostic tester and read the DTCs?
Regards, Markus
