Thread: Coolant leak
Old 10-22-2016, 10:03 PM   #1
particlewave
Are you positive it was coming from the water pump? Since its off, may as well replace it.
If the coolant looked like it was draining from a point just in front of the rear passenger wheel, then its most likely the reservoir tank (cracked tank or bad bleeder valve o-rings).
If its a cracked tank, there will likely be moisture under the trunks foam liner.
