Old 10-19-2016, 09:16 PM   #4
nieuwhzn
nieuwhzn's Avatar
Originally Posted by Racer Boy View Post
Try putting duct tape on the hood seams to see if that changes it. If it does, then you know that is where the problem is.
You can do the same thing with the tape on other parts of the car until the noise goes away, and then you've found the culprit!
Just be sure you remove the tape in short order, as it can leave a nasty residue that is difficult to remove.
Use painters masking tape instead, the blue stuff. Easy to remove, no residue.
nieuwhzn is offline   Reply With Quote
