Old 10-18-2016, 07:30 PM   #1
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
O2 sensors are expensive and there are four of them. Depending on your mechanical abilities, look for the vacuum leak or leaks. They can be a deep rabbit hole that can trigger a lot of different error codes. Buy a code reader, if you don't have one, and you can reset/turn off most codes.
I had my battery out for several days. After I put it back in, I had 1124 and 1126 pop up several times over a week, as the car learned what to do with Calif 91 octane gas. The cars are sensitive and throw codes.
I would suggest that you find a local indy mechanic that knows Boxsters, just in case. See if there is a local PCA chapter. They can be a huge hands on local resource also.
Welcome and congrats on the new car. And kudos for the proper color befitting any Porsche.
