Old 10-18-2016, 11:03 AM   #132
GTsilber
I finally got a durametric and am able to properly diagnose more complicated issues, don't know why I didn't purchase sooner! First thing I did was clear my airbag light and the second thing I did was check my cam deviation values, here they are:
Here are some other p codes that came up when I Ran some diagnostics, I have already replaced the brake pedal sensor and all brake lights are working, not sure why this error keeps popping up.
I also changed my serpentine belt, glad I did as the old one was cracking around the edges.
And I found some time to install my FVD 996 turbo pedals [emoji7]
Here's a list of items that still need to be fixed:
Replace clutch and flywheel
Install new engine mount and shims
Fuel filling issue - unable to fill up
Chain ramp tensioners
Check timing and chains - done
Replace primary cat
A/C - no cold air, compressor and clutch working fine
CV Axles replace
Install technobrace
Wind screen deflectors install
Pedals - done
P0420
P0455
Change serpentine belt - done
Install 997 TB and plenum
Replace MAF
Sent from my SM-G935T using Tapatalk
GTsilber is offline   Reply With Quote
