Old 10-17-2016, 04:18 PM   #4
oldskool73
oldskool73's Avatar
I don't think it'll work 'out the box', if you take a look at the two slots e.g http://i.ebayimg.com/images/g/-swAAOSwTA9X4e51/s-l1600.jpg you can see there's only screw mounts on the top slot which the retaning rails for the climate controls fit into. Also behind that in the metalwork there's a bracket for the radio to rest on in the lower slot. You could probably hack up a solution but it'd be a bit of work.
However I can only speak about the setup on my early car, it's possible it's completely different on your later one? The whole thing comes apart pretty easy, you should just pop the bits out and take a closer look.
oldskool73 is offline   Reply With Quote
