Well I just did my oil change and dropped the sump.
Found just a few tiny black pieces that look like gasket material from the sump, just like yours... No metal. Your brown pieces are the tensionner ramps.
I have the same issue after more than 24 hours of being a queen in the garage... A little noisy then smooth after 3-5 sec. I'm considering replacing my hydraulic tensionner units this winter.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
