Old 10-16-2016, 11:02 AM   #3
Stefan (Boston)
That would be great
However, if you look closely you can see that the plug is slightly different. On the "WD Express" electrical plug there is one side with one tab and one with two. On the OEM Bosch model there are two tabs on both sides.
I'm betting they would both work, if not for the incompatible plugs.
Note that the Kia Optima has one that has the same incorrect plug but has the plug in the same place and direction as the Boxster so it's "closer" but still won't fit, plug-wise.
Cheers.
Stefan (Boston) is offline   Reply With Quote
