Old 10-14-2016, 08:58 PM   #2889
BruceH
BruceH's Avatar
"Yesterday and today (I had to wait on some parts), I replaced the rear trailing arms thanks to the great DIY located here. While I was doing that, I ended up replacing the rear underbody panel and the 2 rear wheel mud guards(all three were worn out), then I did my oil and filter change with no sparkles on my magnetic drain plug, rotated the tires, and then finally I washed and waxed it! My original LN magnetic drain plug failed when I was tightening it back up so I got another one which is a new design and it doesn't look like this one will fail. Oh, and then I took some pictures before I took it for a "test drive" since it was such a nice evening"
So....how exactly did you rotate tires? Aren't your staggered? Mine are.
Right Front to Left Front, Right Rear to Left Rear, not really rotate but swap them.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
