Old 10-14-2016, 06:58 AM   #1
kk2002s
kk2002s's Avatar
Wheel bolts I believe are 96 ft/lbs
Car has 91k miles, if there has been no replacement then a few things will be worn
Lower control arms(Ball Joints), Tie rod ends (maybe inners), drop links and bushings, wheel alignment.
What about your tires, what kind of shape are these in? Any noticeable uneven wear?
Tire pressure? These cars are so sensitive to tires and pressure.
There is no greasing or Ball joint replacement on these cars, you replace suspension components
Seal Grey
