Old 10-08-2016, 06:56 PM   #11
jakeru
Originally Posted by papasmurf View Post
from the key fob that I am getting. I have never had a problem with the button being intermittent in the way it works...possibly the range seems decreased as the battery has aged but that is about all.
Quick blink is good! So, your keyfob blinking light works reliably, but the locking/unlocking action just does not work reliably - correct? If that is the case, your key is a perfect candidate for the solder reflowing procedure I described above!
One word of warning: the components are surface-mount (not through-hole), so you'll need a fairly small/precise soldering iron to access all the solder joints without inadvertently melting the components.
2001 Boxster
