Probem Solved!
Turns out the rubber boot around the left ball joint was torn, hence dirt, hence wear, hence creak. I had both front lower control arms replaced (15 year od car). Two points to note:
You have to replace the entire control arm, not just the ball joint.
If you buy the part online, shop carefully; I saw prices for one arm range from $130 to almost $900!
