Old 10-07-2016, 07:35 AM   #11
edc
550 Anniversary
edc's Avatar
I would have thought that unless you have a good amount of powder or fluid to extinguish a fire ie probably more than a small extinguisher then the last thing you want to do is open up the top and remove the cover and allow in a lot more oxygen. If you have the time to remove the Bose shelf and carpet cover and don't scald yourself on the engine cover clips then you matey as well remove any belongings instead.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
