Old 10-07-2016, 05:44 AM   #10
jonogt6
Hi, as you changed the oil only 100miles ago I'd definitely check the oil filler cap...check its sealing correctly and forming a vacuum.
I had exactly the same thing on a Peugeot 207. I changed the oil and a day or so later the engine management light came on. Turns out the rubber seal inside the cap had split causing a leak. Once it was sorted the management light went out after a day or so - it only resets after its performed several cycles of no faults.
jonogt6 is offline   Reply With Quote
