Old 10-05-2016, 02:17 PM   #12
JFP in PA
Couldn't wiring integrity be tested using a Durametric? You could activate the cam and test for signal voltage at the connector?
While you can activate the system using the Durametric, it is not set up- to read voltages. That would be better accomplished with a multi meter or Power Probe tool.
