Old 10-03-2016, 09:02 AM   #19
JFP in PA
Originally Posted by perspectivism View Post
Could you kindly explain which ones of the ims solutions is considered a permanent fix?
Sent from my Mi 4i using Tapatalk
The LN Engineering IMS Solution is the only permanent replacement for the factory IMS bearing. It is a solid bearing that is fed pressurized oil from the spin on filter adaptor, it has no moving parts, and should outlast your engine.
You can read more an the LN Engineering website, where they have information on all of their IMS retrofit products.
