You could have one of many things happening.
A loose exhaust heat shield is easy to find, tap away at the pipes from underneath with a rubber mallet.
You could have a bad water pump, as you mentioned, or a crapping out idler pulley.
You'll have to pull off the serpentine belt to check.
Good luck with your search.
Six speed 2000 Boxster S
