Old 09-25-2016, 05:43 PM   #7
rfuerst911sc
It's pretty amazing something as simple as the baffles and end caps can make that much of a difference . The baffle is basically a 7 " long tube with perforations in it. The end caps are basically a large washer with 1/4 " holes around the perimeter. Not sure how it works but it does . I also welded in the " silencing washers " which go into the end of the baffle tube. Think of a washer with a 3/4 " hole in it . It worked perfect and should not change over time, if anything it may get a tad quieter as carbon and exhaust " junk " build up on the baffles and SS packing .
rfuerst911sc is online now   Reply With Quote
