sounds like your dead on deleriousga? I forgot to mention Ive had o2 problems my row #1 bank #1 is going bad Ive had chk light on and off Its off now but still should be in the hard data in the ecu. my guess was it was going closed loop but figured with out a chk light on it couldnt be it? but probably is. hope so. Also someone else mentioned that that happened with their maf. These should be similarly related problems. Ill post if the o2 fixed the problem once completed thanks. If anyone else has insight please add.
