Thread: CamShaft Timing
Old 09-23-2016, 12:27 PM   #6
Smallblock454
Hello Bart,
Set engine to TDC. Note what JFP said and rotate again 360 degrees and check if there is any change on bank 1.
Take out the 2 green plugs for the 2 camshafts on bank 2 too. Check if there is a difference of the cam position in relation to bank 1 and tell us what you've found.
Don't start the engine without these green plugs. You'll need new ones before you start the engine.
Regards, Markus
Smallblock454 is online now   Reply With Quote
