Old 09-23-2016, 10:09 AM   #8
Smallblock454
What brand did you use when you replaced the clutch?
A correct installed stock Sachs clutch won't make problems in general. There are a lot of clutches and so called sport clutches out there that suck.
There is also a Sachs performance clutch kit with one mass flywheel and also race kits available. But i would always go with a dual mass flywheel, because it compensates a lot of vibration and helps the crankshaft.
Regards, Markus
