Originally Posted by Smallblock454
Hello,
did you bleed the clutch system (valve) after you've replaced the clutch?
Regards, Markus
I had a local indy shop that does a lot of Porsche work put it in. Sachs clutch kit, IMS Direct Oil Feed, throwout bearing, etc. So, I can't answer that yet, but I'll assume so.
I called him this morning and he was wondering about a loose cable/connection? I'm taking it in on Friday, but any info or help prior is appreciated.
