I think I should be able to make it if I get my sons car fixed.
Here is a google map link of a run that you might like.
It is approx. 2 hours and approx. 140k
I figured to leave from tims in Bracebridge (I put homedepot) they are beside each other.
Either have lunch in Port Carling or Windermere.
Back down to Bracebridge.
This can be extended or shortened.
Here is the link. Hope it works.
https://www.google.ca/maps/dir/Rosseau,+ON/Port+Sandfield,+ON/Port+Carling,+ON/Windermere+Golf+%26+Country+Club,+Golf+Avenue,+Por t+Carling,+ON/The+Home+Depot,+20+Depot+Drive,+R.R.2,+Bracebridge ,+ON+P1L+0A1/Rosseau,+ON/@45.1966709,-79.5656011,10.72z/data=!4m43!4m42!1m5!1m1!1s0x4d2a4598df796389:0x3d7 f3d5c774a6df6!2m2!1d-79.6435917!2d45.2621936!1m5!1m1!1s0x4d2af655666e3a e7:0x3439a27cfdd443e7!2m2!1d-79.616667!2d45.116667!1m5!1m1!1s0x4d2af5b67dd57b61 :0xce51ca4c41058621!2m2!1d-79.575376!2d45.116674!1m5!1m1!1s0x4d2a5e511a082027 :0xe5948d14ca1c1c12!2m2!1d-79.55!2d45.1667!1m10!1m1!1s0x4d2a86c2b486f9ab:0xfc a2b8569ab8c76c!2m2!1d-79.290584!2d45.050378!3m4!1m2!1d-79.3377576!2d45.2915638!3s0x4d2a6ee21a71bd33:0x161 256ce596f6581!1m5!1m1!1s0x4d2a4598df796389:0x3d7f3 d5c774a6df6!2m2!1d-79.6435917!2d45.2621936!3e0
The Loop is correct but the written directions are not in order.
Cheers!
Bart
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
