Thread: Boxster V8
Old 09-18-2016, 01:39 PM   #143
bdra
Not to hijack this thread but I'm looking for a engine swap in my 987.1 Box S. So DME 7.8 can't really be integrated with another ECU even in piggyback fashion. So the donor motor's ECU and harness need to be used. The rationale is to stay with VAG as they may use common sensors and gauges so if you can find an ECU/DME that is open and can be programmed to the Porsche? There's also dimensional constraints of the motor to consider but that's fairly easy to figure out.
Is the 4v ABZ the best choice to integrate into the Boxster S? It seems some people here feel there's other options that might integrate better.
bdra is offline   Reply With Quote
