Old 07-05-2006, 09:18 AM   #1
BACH01
Problem with litronic and high beam
Seems as a light relay problem, please verify.
When i turn on the switch quickly the litronic lights turn on almost always.
When i turn on the switch slowly , i mean , first at the side lights (they light normally always), and afterwards the switch to the dipped beam there seems a tiny flash in the litronic bulb but then the litronic bulb doesn't light.
In that case also the high beam doesn't light continously,
but the headlight flasher lights normally(i guess the current in the flash mode flows from another way).
Any help appreciated.
Greetings
Katerina from Greece.
BACH01 is offline   Reply With Quote
