2000986S, I do not believe it does fit a 986 S. IT connects to a single pipe coming from the two mufflers of the 987 S. The ID on the tip section is 2.75". It connects with the exhaust clamp used to connect the OEM tip. IF the 986 S setup is like this then it may fit. I see you live in Wheaton. I live just west of Joliet so am not far from you.
