Old 07-05-2006, 06:05 AM   #6
tifosi00
thank you for all your advice, and thoughts.
One thing I forgot to mention is that it seems to start more often when I start to turn slightly right. I do have aftermarket wheels that are wider, 9 inch in the front and 10 in the back.
The weird thing is it doesn't start only when turning right, it sometimes starts in a straight line, but most often when I start to turn right, then will go away when I turn straight again.
I will check out the emergency brake cable, I had not thought of that before.
If it has something to do with the flywheel, I will just leave it until I need a new clutch.
My car is out of warrantly, I have 60,000 miles on it now.
Thanks again for any thoughts.
Mike
tifosi00 is offline   Reply With Quote
