Old 09-14-2016, 06:20 PM   #11
BYprodriver
BYprodriver's Avatar
Why do you think the 2003 is 400lbs heavier? The only difference in weight between a 2003 and 97 is the top is slightly heavier. Everything else is basically the same. An automatic will be heavier than a 6 speed and a six speed will be heavier than a five speed.
It could be as much as 400 lbs heavier. Since OP did not list specifics I used worst case scenario from factory curb weights. Early '97's did not have airbags or Bose stereo's with amp's & subwoofers. Lots of ways for the 2003 to gain weight.
