Old 09-14-2016, 04:49 PM   #11
WillH
WillH's Avatar
Feel free to try blasting, but I had no luck getting the final bits of silver out of the corrugated backing where it meets the lip that fits into headlight case. The other issue I had was static and blowing clean the inevitable blasting media that gets past the masking material. Sanding was a no go in the same area. Perhaps with more patience and a willingness to remove the corrugation and a section of the lip to get to the very last points of silver that can be seen from the exterior.
Ended up painting the exterior shell to get rid of the eyeliner. Epoxy black was a good match to the factory black paint but fades in sun. Will redo this winter,(paint and polish), then seal with 2k clear.
