Old 09-13-2016, 09:53 PM   #2
Gilles
studs..?
it also helps a great deal to use studs to align the transaxle to the engine, you can cut the hex head off two or three spare/old bolts (same as the ones holding the gearbox and engine together) and these will guide the transmission into the engine (you may have to rotate the engine a teeth or two), then replace the studs with the right bolts.
Gilles is offline   Reply With Quote
