Fuzzuki, if I understand correctly, you can remove the outer lenses from your original headlight assemblies, then remove the outer lenses from the replacement assemblies you bought and install the original lenses on the replacement assemblies. You'll need to remove the outer lenses on all of the headlights to do what you want to do. I'm not sure you can get the inner lenses and other inner parts out without breaking something. So just swap the outer lenses on the units. How bad are the housings that you can't use them again? If it's just the gaskets you can change those, you need to remove them to get the outer lenses off anyway.
