Old 09-13-2016, 06:15 AM   #5
RichRobby
Originally Posted by Lexky View Post
I managed to clear my airbag light with an OBDII scanner. The scanner must have airbag support.
Note: scanner will only clear a tripped code, if other issue exists the fault can reappear.
In my case I had disconnected airbag, which tripped the fault after reconnecting airbag.
Interesting
I tried this cheap version (only about 10 GBP) and it doesn't find the error, even though it says it should.
www.amazon.co.uk/gp/product/B01AC7I7BO
Do you know what one you successfully used?
RichRobby is offline   Reply With Quote
