Paul is correct on all points. Also, you can use the switch from '97 to '04 Boxsters or 996s. '97 to '01 have a gloss finish and the later ones have a matte finish. When installed, the difference in finishes is not that noticeable. The swapping of the OBC stalk is very easy. As Paul said, replacing the switch requires some work but is a doable DIY.
If you don't have either cruise control or the OBC now is the time to add them.
Now, finding a reasonably priced switch and getting it and installing it before Friday will be challenging. Good luck and keep us posted.
1995 Porsche C4 Cab
