Old 09-12-2016, 04:20 AM   #1
itsnotanova
Pretty sure they will but the 2003 will be about 400 lbs heavier so it will probably raise the car ride height & definitely not as designed by Porsche.
Why do you think the 2003 is 400lbs heavier? The only difference in weight between a 2003 and 97 is the top is slightly heavier. Everything else is basically the same. An automatic will be heavier than a 6 speed and a six speed will be heavier than a five speed.
Woody
