Originally Posted by insite
i'm confused. go ahead and post all of your readings. for clairity, when you say:
Short Term Fuel Trim: On the highest load (68.2%, 4675rpm@91mph) the short term fuel trim was -1.6% on bank 1 and -3.1% on bank 2. The breakdown was 0% bank 1, sensor 1, 99.2% bank 1, sensor 2, -3.9% bank 2, sensor 1, 99.2% bank 2, sensor 2.
i'm interpreting:
when the engine load was 68.2%, short term trims were -1.6 and -3.1.
i'm not sure what you mean when you say the 'breakdown' was 0% bank 1 sensor 1, 99.2% bank 1 sensor 2. i'm not sure what the percentage readings you're providing me for the o2 sensors mean.
I'm not sure what the percentage readings are. They are listed as fuel trim readings and not listed as O2 sensors.
in the meantime, you mention rough idle. do the follwing before you buy anything else:
1. clean your idle air control valve
2. check for vacuum leaks. obvious culprits are the bellows tube below the oil separator and the oil filler tube
post the rest of your numbers and we'll see what we can figure out.
I will check again for vacuum leaks. I don't think that's the issue this time since the problem goes away immediately when I clear the codes. I'll clean the IACV too and make sure there is nothing freaky going on with that. I'll post the results as soon as I get to these. I'm working on the clutch in the 928 today so we have two cars running again.
Thanks!
