Old 09-10-2016, 03:38 PM   #1
tlank21
986 Parts - Rear Drain Screens, Washer Fluid Reservoir, Headlamp Sprayers
I have a few items for the 986 Boxster which I am trying to get ride of.
1. Rear Drain Screens - $15, Brand new in package – part no.: 987.561.487.00
2. Expanded volume Washer Fluid Reservoir - $75, Used, part no.: 99652870100
Part was thought to be cracked. Upon further inspection the pump for the front headlamp washers was severely corroded and the washer fluid was leaking through the pump - the reservoir was leaking through pump but does not appear to be cracked.
The system includes the expanded washer fluid reservoir with the single window washer pump and hose connection (the headlamp pump was corroded and thrown away). The hose for the headlamp washer is included, however. One would need to purchase a new headlamp washer pump for full functionality.
The headlight pump is relatively inexpensive and can be found here at ******************************************** for $37.00:
M288 Headlight Washer System
Note: I was thinking that someone could utilize this set up for an expanded washer fluid reservoir with only window washer function by simply plugging the hole for the secondary pump (headlamp pump).
3. Headlamp Sprayers (2) - $150, good condition, part no.: 99662833300 and 99662833400
I could not confirm that both of these sprayers are in full operational condition due to the corroded headlamp washer pump being corroded (see above). However I believe they should be working, the sprinkler type nozzle end slides up and down with ease.
The passenger side sprayer is brand new, due to a recent front bumper accident and replacement.
The driver side sprayer is used but looks to be in operational condition as well.
These retail for $200 each, now set at $75 each.
Pictures of all items can be viewed through the google drive shared link below:
https://drive.google.com/open?id=0B5aai4j1U0c4dU1kdF9kd09fRW8
tlank21 is offline   Reply With Quote
