Thread: AOS - Question
Old 09-10-2016, 03:07 PM   #11
Muskoka Minute
Muskoka Minute's Avatar
well this is where were at...
I just changed the AOS and here is what we did etc.
1, Started the eng and we got less smoke than normal. (check eng light was still on) After 5-10 min the smoke was all gone.
2. let it ideal for approx. 15min
3. took it for a test drive. After approx. 3 mile. It was running rough, check eng light was flashing.
4. shut it off
5. restarted - running rough. shut it off
6. re started, started for home. It started to run better and the check eng went to solid and not flashing. Shut it off
7. Got home and re started. Runs like **************** and is making noises.
Here is the video.
https://vimeo.com/182244036
You will have to cut and past as I don't know how to make it an active link.
Please Help!!!
It ran perfect after the first fire up with the new AOS.
I have no idea why this is happening.
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
