Thread: Gauge Pod trim
Old 09-10-2016, 08:31 AM   #2
KevinH1990
KevinH1990's Avatar
The non-S does not have the gauge trim rings and and the standard color of the gauge faces is white on black. (You could order black on silver as an option.) I have never looked closely, but the analog speedometer on the S may have a higher maximum speed. (I know that is the case for the 996 clusters.)
You can find instructions for taking apart the cluster here: Programming a 996 Cluster to Work in a 986 - Rennlist Discussion Forums
You could remove the plastic cover from your donor cluster and swap it onto your cluster. Then you could remove the trim rings from your S cluster cover and install them on the donor.
