Old 09-09-2016, 04:53 AM   #3
Shandy
Hi.
It's a RHD with OEM headlamps. I did try searching the forum but can't find any symptoms the same as mine. There does seem to be voltage at both connectors when the headlamp units are removed and the high beam stalk is activated so I assumed the headlamp switch must work OK?
Thanks, Paul
Shandy is offline   Reply With Quote
