Old 09-08-2016, 01:40 PM   #21
Adrian Thompson
Not much has happened as I've been completely out of action with my back. Back surgery 3 weeks ago has left me a completely different person. I'm out of pain for the first time in over 6 months and can move so, so much better. Stunned to find we've put almost 5K miles on the Boxster since getting it considering I haven't driven for a month and it was in the body shop for 4 weeks.
So the weekend I got originally it failed to start. Looked like a dead battery so I replaced that, but since then things have been getting weak so I've kept it on a battery tender, but last week the alternator died so I needed to fix that. Reading online and in the 101 Boxster projects book indicates that you need access from the top side of the engine, as well as through the front from the passenger area. I'll tell you now there is no need to go through the top, the whole operation can be done through the front access. The only think you need to go through the top for is to undo one earth strap, but I see no need to do that. It was worthwhile going through the top as the engine was filthy covered in dust and It gave me a chance to swap the air filter.
Pics. Putting the soft top in the service position is easy. Open part way, pop off a couple of top cables from their ball sockets and hold the hood out of the way with a bungee. This is the cable, one each side.
Then remove the glove box/carpet and the rear carpet.
Finally remove the engine cover to reveal the filthy engine. This represents 12 years and 20-25K miles of grime I assume since the brand new engine was fitted by Porsche.
YEah, the air filter is past it's best
OK, inside, move both seats forward, remove the rear carpet/matt with 4 plastic push pins then something like 8 bolts to remove the cover. Dead easy, faster and easier than I was expecting to tell the truth.
To remove the alternator there are just two bolts. The lower right (left if your in the car looking back at the front of the engine) just comes out. The other is the lower left (right looking at the front of it) is also an idler pulley. Undo that about 4-5mm then wack on the end with a drift and a metal hammer. The reason for this is that there is a bucking in the alternator rear housing that get's pulled into the mount as you tighten it up to help locate it. This has to be pushed back into the alternator to allow it to be removed. This was the toughest part as it was a bit stuck, but not too bad. Then carefully rotate the alternator CCW as you look at it, pull it forward and remove the connects.
Part way out. As you can see, lots of room actually to reach stuff.
I'd called a friend who works at the local Porsche dealer so I texted him and there was a new accessory belt and air filter waiting for my credit card at the dealer when I stopped there after picking up rebuilt alternator from a local re-builder.
It went back together like a dream and was running soon.
https://www.youtube.com/embed/pPG484iUKNw
Then I filled a garden weed sprayer with hot hot water and simple green and spent 30 mins cleaning up the engine before putting the covers back on. Nice and easy and made a massive difference.
Then a thorough cleaning of the trim and carpet bits and put it all back together. All in all easier than I expected, access really isn't as bad as people lead you to believe and it was quicker than an SVT Contour alternator swap that I can do in 3 1/2 hours start to finish despite internet lore saying it's a full day job with a lift that I never had.
Budget 1999 986. Not much, but it's mine all mine.
Volvo C30 picked up Euro delivary 6/26/08 drove the Nurburgring 6/30/08
Adrian Thompson is offline   Reply With Quote
