Old 09-07-2016, 10:26 PM   #4
ttomtom
I don't use a stalk at the moment. I use two extra dash switches, each can do two functions. I have Ohmed them out and also shorted the wires coming from the cluster to ground. The only thing that happened is the trip odo was reset when I held the appropriate one shorted. This means the wires/connections are ok. At least that one that reset the trip odo which is probably the "down" one that should cycle through the different readings if the OBC was really enabled.
Yes I've downloaded the latest Durametric.
ttomtom is offline   Reply With Quote
