Old 09-07-2016, 09:24 PM   #3
Pdwight
Pdwight's Avatar
I had a similar problem when I started building my OBC harnesses. I even managed to get my hands on a PIWIS and no luck. Turned out it was a switch not working in the 4 stalk.....bad solder joint. Take an ohm meter and ohm the stalk out to at least elminate that variable. If you need a professionally constructed 4 stalk harness for your car let me know.
