					Originally Posted by littlewiggler  (Copy of email I sent to Durametric support - hope maybe someone here may have an idea)
 I just received my Durametric Enthusiast.
 I was able to connect it to my 03 Boxster.  No codes (Yay!)
 I have installed the OBC stalk, and it appears to be installed correctly.  If I move the stalk in any of the directions at start up the oil level screen goes away.
 I have tried to enable the OBC via the Durametric but have been unsuccessful.
 The first time I try I get the following error:
 Coding Change Failed
 If I try again I get:
 Did not receive the correct number of bytes from the control module.
 If I try a third (or any consecutive) time it states that it is enabled (but it is not)
 Same happens when I try to disable it.
 Any ideas?
I wonder if this has been sorted out.
Same "Did not receive the correct number of bytes from the control module" error message here with Durametric Pro on a 2001 Boxster S
