Old 09-06-2016, 07:45 PM   #10
madmodz
madmodz's Avatar
[QUOTE=Rok986;509173]
Starting from the vacuum reservoir: Connect to electric change-over valve "J", then to the flapper valve. The Y "I" in the diagram will only be present if you have a Tiptronic.
"E" is located behind the Alternator.
Thanks! I will take another look. Do I have to remove the alternator to be able to access "E"?
Nope, it connects to the bottom of D
madmodz is offline   Reply With Quote
