[QUOTE=78F350;509073]Starting from the vacuum reservoir: Connect to electric change-over valve "J", then to the flapper valve. The Y "I" in the diagram will only be present if you have a Tiptronic.
"E" is located behind the Alternator.
Thanks! I will take another look. Do I have to remove the alternator to be able to access "E"?
